temp problem
Posted: Sun Dec 13, 2015 12:44 am
HI im having a problem with my ME DUCER printer the temp always says 270 so i thought i would order a new temp prob but that did not help.
If i put heat past 270 then it will start to work. so i thought it may be coming from the board so i swapped the bed and head temp and its till doing this so i know now that its coming from the board even if i unplug that port is says 270. is there a was to calibrate the board back to 0
