3D printer firmware i3 Pro C
I have searched for firmware for i3 Pro C dual.
I have accidentally deleted firmware and after that I found one working one but still it is not latest one.
Where can I get latest firmware?
Also have some issues with printer.
If I start printing and nossle is not in home position it start to go over max borders, that should not happend.
Also I noticed that when I start printing and because of some problems stop printing and starting all over again nossle starts to print 2mm from heatbed.
I need to stop it again and start printing again and than it is ok. I always need to print twice to print ok.
Re: 3D printer firmware i3 Pro C
download it here:
http://www.geeetech.com/forum/viewtopic ... 10&t=17046
"I need to stop it again and start printing again and than it is ok. "
I think your Z axis endstop must have been bad contact, as this had happened to my printer before.
thank you, but this firmware have an error, doesn't work.
Arduino:1.6.7 (Windows 7), Plošča:"Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
unable to find a register to spill in class 'POINTER_REGS'
What do you mean Z stop bad contact.
Maybe is it bad switch?
Don't use the latest arduino, it always has some problems when compling. Use arduino 1.0.1, it's more useful.
You can swap the Z axis endstop with X axis one to see if it happens in X axis. And I mean the endstop wirings might be loose or something, sometimes it might tell the Z axis to stop even not triggered.
1.0.1 arduino works, compiled and uploaded.
I already swap end switches but can not tested because I have MINTEMP error
I get this from technical support
http://www.geeetech.com/forum/viewtopic ... 13&t=17030
But there is a problem, because When I make shortage on thermistor pin I get
Err: MAXTEMP
when I disconnect thermistor I don't get anything no Err: MINTEMP
Also have reset display everytime.
And after a minute of printing I always get this Err:MINTEMP
I checked heatbed if there is a bad connection or something but no all is ok.
also measured NTC it have about 80kOhm heatbed about 3 ohm.
Err: MAXTEMP
- IMG_2483.rar
- (669.34 KiB) Downloaded 650 times
when you disconnect the thermistor, what's the readings of the LCD? if it isn't 0, then the board is defective.
When I disconect thermistor it is 0 oC
0/0 o
any time I do that,
but no err: MINTEMP
0/0 o
any time I do that,
but no err: MINTEMP
how about change the MIN temp here to 0 and upload it, test is again:
#define HEATER_0_MINTEMP 5
#define HEATER_1_MINTEMP 5
#define HEATER_2_MINTEMP 5
#define BED_MINTEMP 5
It works now.
But I think something is wrong with extruder temperature.
It jums up and down from 204 oC to 235 (204/230 o)
I have set temperature for extruder 230 oC.
I think thats why that error shows up!
tie your thermistor up, sometimes it will move around due to the movements of the nozzle and reads imprecise, and keep the fan from blowing at it.
