Extruder Feed Rate
Posted: Thu Jan 07, 2016 4:43 pm
by hooked
I want to be able to change the extruder feed rate for different filament types. Is there a way to do this in the firmware? Or any other method that I can use to change the feed rate.
If I extrude 100mm via Repetier manual settings the printer actually extrudes 115mm. So I want to set this up to give the correct feed rate.
THANKS
Daryl
Re: Extruder Feed Rate
Posted: Fri Jan 08, 2016 4:50 pm
by Mark
you can set up the E steeps as the calibration guide shows:
http://reprap.org/wiki/Triffid_Hunter's ... de#E_steps
Posted: Fri Jan 08, 2016 5:33 pm
by hooked
Thanks, can you please tell me which gear ratio is relevant for my G2 to use for E step calculations.
Cheers
Daryl
Posted: Sat Jan 09, 2016 4:23 pm
by Mark
I can't remember it , seems to be 11/5...but I think you can calculate it in this way, manually extrude 30mm, compared to the actual filament length and then increase or reduce the steps.
Posted: Sun Jan 10, 2016 5:11 am
by hooked
Thanks Mark,
I will try that.
Can you tell me the actual syntax for the code that I need to enter into Marlin firmware.
I cant find it anywhere searching the net.
THANKS
Daryl
Posted: Mon Jan 11, 2016 4:17 pm
by Aliraza521
And how about the resistanc of your hotbed, it is usually 1.2-1.5ohms, if too high then the temperature won't pass 100 degrees, check this link:???
Posted: Mon Jan 11, 2016 4:56 pm
by Mark
you can find the steps/mm in configuration.h tab of your firmware and change it :
#define DEFAULT_AXIS_STEPS_PER_UNIT {80,80,2560,93} // MXL, Z M8=1.25, MK8
