HI
I assembled my new G2S PRO and make it works.
I made some little prints with success, but when I tried the second extruder I experienced difficulties.
In fact my spider is not always horizontal but has a varrying tilt. When it is near the Z axis the hot_end 1 is closer to the bed and when it is at the opposite of the Z axis the hot-end 2 is closer to the bed. It make the level adjustment impossible for the two hot-ends.
I investigate the problem and found that 5 of the 6 hot end has length of 198.8 mm and the last one 196mm. So like that my printer is not really usable.
Where could I find a diagonal rod the fit my the other ones ?
Different lenfth for diagonal rods on G2S PRO
Re: Different lenfth for diagonal rods on G2S PRO
uh...seems the only way is to replace it.
Yes replace it would be good, but how can i do that ?
Could you send one of the good size to me ?
it's hard to say...you need to contact the sales to talk about this.
Hey mate
I just built mine and noticed I've got the same problem:/
Did you end up fixing it? And if so how??
