Problem with Y axis
Posted: Wed Jan 20, 2016 6:47 am
by scoelho
I have a I3 pro C and I already print some parts on my printer in the past. Now, when I need to print another pieces when I start the printer today, when I do autohome the Y axis start moving extremely fast and doing much noise on moves.
So I would like to know what´s happening with the printer and what´s the problem.
It´s a problem of any piece in specific??
Thanks for any help in advance.
Re: Problem with Y axis
Posted: Thu Jan 21, 2016 11:10 pm
by Mark
does the driver working well? and the motor, is it wroking well on the other axis?
Posted: Fri Jan 22, 2016 7:36 am
by scoelho
I reinstall the firmware and already put the i3 B firmware, but keep the same problem.
I tested too change the motor of Y axis but stayed with the same problem...
I really don't know what´s happened with this...
Posted: Fri Jan 22, 2016 4:42 pm
by Mark
step by step to check it:
1) check the motor. Plug the motor to the X axis connector, if it's working well on X axis then motor is good.
2)check the motor driver. Interchange the driver with the X axis one, if the same thing happens in the X aixs motor then the driver is dead or voltage is not proper, you can adjust it.
3) check the formware, you need to install the one for your I3 pro C not pro B.
4) also check the subdivision of the driver, check this link:
5) the last one, if the firmware, motor driver, motor cable and motor itself are all in good condition, then maybe the board is defective, need to replace it.
Posted: Mon Jan 25, 2016 2:54 am
by scoelho
1) motor is good
2) driver is good
3) I reinstall again the firmware
4) i dont change the power of drivers because i test it with the driver of z axis and x axis and always have the same problem
5) the cable its ok too, i test it with other cable. About the the board if it had some defective do you know what can cause this. Because i buy my printer on May of 2015 and i think its not normal the board take some problem in a too short time, and with only 1 coil of filament until now...
Thank you for your patience.
Posted: Mon Jan 25, 2016 5:15 pm
by Mark
don't know the reason but a friend run into this problem too, the Z axis of his printer works fine during the home procedure, but when you manually comtrol it, it will run pretty fast and need a emergency stop. Changed a new board and it's working.
Posted: Tue Feb 16, 2016 11:30 pm
by elocm
On the Y-axis please check the bearing at the belt, if ti wobble. Maybe needs replacement. Additionally check travel speed: 130mm/s is working fine 300mm/s also causing my Y-Axis this wobble and miss align form time to time. maybe driver. Also to much tension on the belt could be a problem.
