X-homing doing in wrong direction
Posted: Tue Feb 09, 2016 8:22 am
by khondoke
Hello, I am talking about Geeetech Pro C Dual Extruder system. whenever it is homing at X-axis, the extruder doesn't go to the correct direction to hit the endstop rather it goes to the other way. I am using Repetier-Host and tried to solve this by changing printer setting. But no hope. I did these two: (1) Printer Settings > Printer > Invert Direction in Controls for (X-axis) - I checked it for X axis but problem continues. (2) Second, Printer Shape > Home X Min Or Max (tried for both) but same. Would you anyone please be able to help me how can I reverse the X-direction while homing? Thank you very much.
Re: X-homing doing in wrong direction
Posted: Tue Feb 09, 2016 9:24 pm
by Mark
I remember the Pro C cannot reverse the direction on the LCD, only in the firmware, check out this link:
http://www.geeetech.com/forum/viewtopic ... 17&t=17037
Posted: Wed Feb 10, 2016 2:29 am
by khondoke
Thanks Mark. Problem solved. The original pre-loaded firmware had problem, I think. I only downloaded the firmware you suggested and uploaded without any modification. And it worked. Thanks again. :)
Posted: Wed Feb 10, 2016 12:32 pm
by khondoke
Hello Mark, As I mentioned in last comment that, I mistakenly downloaded and uploaded the firmware for Pro X (I3_Pro_X) but my printer is Pro C dual extruder. Because of that, the second extruder is not working at all (as expected). So, now I tried to download and upload the correct firmware (Marlin_GT2560-PI3_Pro_C). When I uploaded, it could not succeed and gave the following error. Could you please help me finding the correct firmware for my printer and suggest any necessary step to make it fully operational? Thank you very much. The title of the error was: (unable to find a register to spill in class 'POINTER_REGS')
Code: Select all
Arduino: 1.6.7 (Windows 10), Board: "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
                 from sketch\BlinkM.cpp:5:
sketch\pins.h:2956:0: warning: "X_MAX_PIN" redefined [enabled by default]
 #define X_MAX_PIN          -1
 #define X_MAX_PIN 24
sketch\pins.h:2957:0: warning: "Y_MAX_PIN" redefined [enabled by default]
 #define Y_MAX_PIN          -1
 #define Y_MAX_PIN 28
sketch\pins.h:2958:0: warning: "Z_MAX_PIN" redefined [enabled by default]
 #define Z_MAX_PIN          -1
 #define Z_MAX_PIN 32
                 from sketch\ConfigurationStore.cpp:1:
                 from C:\Users\MohammadAbuHasan\Dropbox\Geeetech Pro C\Firmware for GT2560_Pro C Dual Extruder Geeetech 3D Printer\Marlin-PI3_Pro_C\Marlin\Marlin.ino:33:
                 from sketch\MarlinSerial.cpp:23:
sketch\Marlin_main.cpp:2667:36: warning: invalid suffix on literal; C++11 requires a space between literal and identifier [-Wliteral-suffix]
                 from sketch\Sd2Card.cpp:20:
                 from sketch\SdBaseFile.cpp:21:
                 from sketch\SdFatUtil.cpp:20:
                 from sketch\SdFile.cpp:20:
                 from sketch\SdVolume.cpp:20:
                 from sketch\Servo.cpp:44:
                 from sketch\cardreader.cpp:1:
                 from sketch\digipot_mcp4451.cpp:1:
                 from sketch\motion_control.cpp:22:
                 from sketch\planner.cpp:54:
                 from sketch\qr_solve.h:1,
                 from sketch\qr_solve.cpp:1:
                 from sketch\stepper.cpp:24:
                 from sketch\temperature.cpp:32:
sketch\temperature.cpp:565:50: warning: extra tokens at end of #ifdef directive [enabled by default]
     #ifdef THERMAL_RUNAWAY_PROTECTION_BED_PERIOD && THERMAL_RUNAWAY_PROTECTION_BED_PERIOD > 0
sketch\temperature.cpp: In function 'void manage_heater()':
temperature.cpp:665: error: unable to find a register to spill in class 'POINTER_REGS'
temperature.cpp:665: error: this is the insn:
(insn 98 97 100 4 (set (reg/v:SF 103 [ pid_input ])
        (mem:SF (post_inc:HI (reg:HI 146 [ ivtmp.209 ])) [4 MEM[base: _110, offset: 0B]+0 S4 A8])) sketch\temperature.cpp:449 99 {*movsf}
     (expr_list:REG_INC (reg:HI 146 [ ivtmp.209 ])
        (nil)))
sketch\temperature.cpp:665: confused by earlier errors, bailing out
Multiple libraries were found for "LiquidCrystal.h"
 Used: C:\Users\MohammadAbuHasan\Documents\Arduino\libraries\LiquidCrystal
 Not used: C:\Program Files (x86)\Arduino\libraries\LiquidCrystal
exit status 1
  enabled in File > Preferences.
Posted: Wed Feb 10, 2016 7:27 pm
by Mark
This error is mainly caused by the arduino version, try to use arduino 1.0.1, it's more useful. And you can check the user manual to make the printer work, it will tell you how to calibrate the printer and print a single plate from the beginning to the end.
Posted: Thu Feb 11, 2016 3:12 am
by khondoke
Thanks. All set now.
