No software communication with GT2560 Rev A
Posted: Sun Feb 14, 2016 3:14 am
I have an i3 Pro X and I am having a hell of a time getting any communication from the Repetier-Host. Repetier-Host version is 1.6.0 and Repetier-Server version is Free 0.70.1.
The server connection shows that it is connected to the printer, if I disconnect it the printer, I can then reconnect it. The same goes for the host software. With the host software connected to the server, the log lines just continually scroll the following:
11:10:59.956 : Warning: Communication timeout - resetting communication buffer.
11:11:02.253 : echo:SD init fail
11:11:02.253 : echo:Unknown command: " "
11:11:03.019 : echo:Unknown command: " "
11:11:23.256 : echo:enqueing "G28"
11:11:56.589 : Warning: Communication timeout - resetting communication buffer.
11:11:56.589 : echo:Unknown command: ""
11:12:03.553 : echo:Unknown command: " "
11:12:41.641 : Warning: Communication timeout - resetting communication buffer.
11:12:41.641 : echo:Unknown command: "[ "
11:12:41.646 : Error:No Line Number with checksum, Last Line: 0
11:13:12.662 : Warning: Communication timeout - resetting communication buffer.
11:14:01.747 : Warning: Communication timeout - resetting communication buffer.
11:14:50.754 : Warning: Communication timeout - resetting communication buffer.
11:15:00.818 : echo:Unknown command: " "
11:15:01.818 : echo:Unknown command: "V7 "
11:15:41.746 : Warning: Communication timeout - resetting communication buffer.
11:15:45.793 : echo:Unknown command: " "
11:15:59.796 : echo:Unknown command: "ed "
11:16:32.796 : Warning: Communication timeout - resetting communication buffer.
11:16:43.832 : echo:Unknown command: ""
11:17:22.859 : Warning: Communication timeout - resetting communication buffer.
11:17:22.960 : Warning: Communication timeout - resetting communication buffer.
11:17:25.941 : echo:Unknown command: ""
11:17:38.963 : echo:Unknown command: ""
11:17:39.963 : echo:Unknown command: " "
11:17:40.956 : echo:Unknown command: " "
11:18:14.988 : Warning: Communication timeout - resetting communication buffer.
11:18:25.053 : echo:Unknown command: " "
11:18:26.147 : echo:Unknown command: " 7 "
11:19:06.076 : Warning: Communication timeout - resetting communication buffer.
11:19:10.143 : echo:Unknown command: " "
11:19:24.146 : echo:Unknown command: " d "
11:19:57.074 : Warning: Communication timeout - resetting communication buffer.
11:20:08.123 : echo:Unknown command: ""
11:20:47.176 : Warning: Communication timeout - resetting communication buffer.
11:20:51.224 : echo:Unknown command: ""
11:21:05.117 : echo:Unknown command: " "
11:21:25.104 : Repetier-Server disconnected.
11:21:57.624 : Repetier-Server successfully connected.
11:22:29.130 : Warning: Communication timeout - resetting communication buffer.
11:22:29.239 : echo:Unknown command: "i $ "
11:22:29.239 : echo:Unknown command: ""
11:22:32.192 : echo:Unknown command: "Q "
11:22:46.210 : echo:Unknown command: "Z "
11:23:21.216 : Warning: Communication timeout - resetting communication buffer.
11:23:27.233 : echo:Unknown command: "i "
11:24:09.240 : Warning: Communication timeout - resetting communication buffer.
11:24:58.264 : Warning: Communication timeout - resetting communication buffer.
11:25:47.272 : Warning: Communication timeout - resetting communication buffer.
11:26:36.278 : Warning: Communication timeout - resetting communication buffer.
11:27:25.285 : Warning: Communication timeout - resetting communication buffer.
11:28:14.309 : Warning: Communication timeout - resetting communication buffer.
11:29:03.318 : Warning: Communication timeout - resetting communication buffer.
11:29:52.341 : Warning: Communication timeout - resetting communication buffer.
11:30:41.463 : Warning: Communication timeout - resetting communication buffer.
11:31:30.473 : Warning: Communication timeout - resetting communication buffer.
11:32:19.497 : Warning: Communication timeout - resetting communication buffer.
11:33:08.505 : Warning: Communication timeout - resetting communication buffer.
11:33:57.523 : Warning: Communication timeout - resetting communication buffer.
11:33:59.602 : echo:Unknown command: "Y "
11:34:13.605 : echo:Unknown command: "i "
11:34:48.611 : Warning: Communication timeout - resetting communication buffer.
11:35:37.637 : Warning: Communication timeout - resetting communication buffer.
11:36:26.647 : Warning: Communication timeout - resetting communication buffer.
11:37:15.655 : Warning: Communication timeout - resetting communication buffer.
11:38:04.663 : Warning: Communication timeout - resetting communication buffer.
11:38:53.673 : Warning: Communication timeout - resetting communication buffer.
11:39:42.681 : Warning: Communication timeout - resetting communication buffer.
11:39:42.790 : Warning: Communication timeout - resetting communication buffer.
11:40:31.798 : Warning: Communication timeout - resetting communication buffer.
11:41:20.807 : Warning: Communication timeout - resetting communication buffer.
11:42:09.816 : Warning: Communication timeout - resetting communication buffer.
11:42:58.824 : Warning: Communication timeout - resetting communication buffer.
11:43:11.842 : echo:Unknown command: " "
11:43:14.905 : echo:Unknown command: "i "
11:43:49.911 : Warning: Communication timeout - resetting communication buffer.
11:43:50.895 : echo:Unknown command: "i ( "
11:43:57.912 : echo:Unknown command: " "
11:44:00.866 : echo:Unknown command: "O "
11:44:41.888 : Warning: Communication timeout - resetting communication buffer.
11:44:44.951 : echo:Unknown command: "X "
11:44:58.954 : echo:Unknown command: "i "
11:44:59.938 : echo:Unknown command: "9i) "
11:45:33.960 : Warning: Communication timeout - resetting communication buffer.
11:46:22.969 : Warning: Communication timeout - resetting communication buffer.
11:47:11.978 : Warning: Communication timeout - resetting communication buffer.
11:47:15.042 : echo:Unknown command: " "
11:47:16.026 : echo:Unknown command: "W7 "
11:47:30.029 : echo:Unknown command: " "
11:48:03.941 : Warning: Communication timeout - resetting communication buffer.
11:48:14.005 : echo:Unknown command: "fd "
11:48:54.044 : Warning: Communication timeout - resetting communication buffer.
11:48:58.092 : echo:Unknown command: "it "
11:49:11.001 : echo:Unknown command: ""
11:49:45.023 : Warning: Communication timeout - resetting communication buffer.
11:49:55.087 : echo:Unknown command: " "
11:49:55.087 : echo:Unknown command: "i "
11:49:56.072 : echo:Unknown command: " "
11:50:37.094 : Warning: Communication timeout - resetting communication buffer.
11:50:40.048 : echo:Unknown command: " "
11:50:41.142 : echo:Unknown command: " 7 "
11:50:55.145 : echo:Unknown command: " "
11:51:29.057 : Warning: Communication timeout - resetting communication buffer.
11:51:39.121 : echo:Unknown command: " d "
11:52:19.159 : Warning: Communication timeout - resetting communication buffer.
11:52:23.206 : echo:Unknown command: "i "
11:52:36.115 : echo:Unknown command: ""
11:53:10.110 : Warning: Communication timeout - resetting communication buffer.
11:53:20.250 : echo:Unknown command: " "
11:53:28.251 : echo:Unknown command: "i "
11:54:01.311 : Warning: Communication timeout - resetting communication buffer.
11:54:01.311 : echo:Unknown command: "i ! "
11:54:13.346 : Error:No Line Number with checksum, Last Line: 0
11:54:16.436 : Error:Line Number is not Last Line Number+1, Last Line: 0
11:54:16.436 : Resend: 1
11:54:52.427 : Warning: Communication timeout - resetting communication buffer.
11:55:00.477 : echo:Unknown command: " "
11:55:42.541 : Warning: Communication timeout - resetting communication buffer.
11:55:44.523 : echo:Unknown command: " "
11:55:46.510 : echo:Unknown command: "i) "
11:56:33.645 : Warning: Communication timeout - resetting communication buffer.
11:57:22.765 : Warning: Communication timeout - resetting communication buffer.
11:58:11.884 : Warning: Communication timeout - resetting communication buffer.
11:59:01.002 : Warning: Communication timeout - resetting communication buffer.
11:59:01.003 : Warning: Communication timeout - resetting communication buffer.
11:59:50.027 : Warning: Communication timeout - resetting communication buffer.
11:59:50.118 : Warning: Communication timeout - resetting communication buffer.
12:00:39.146 : Warning: Communication timeout - resetting communication buffer.
12:00:39.147 : Warning: Communication timeout - resetting communication buffer.
