Page 1 of 2
				I2
				Posted: Tue Feb 16, 2016 1:41 pm
				by Beniamino
				Would anyone be able to tell me please how to get started on the Prusa I2? I bought it on eBay and the guy said he'd help but I think he forgot how to use this one now. I have used Arduino Uno and Nano before but whatever board this is I don't know how to use. Any help would be appreciated.
				Re: I2
				Posted: Tue Feb 16, 2016 8:29 pm
				by Mark
				I2? what type of printer do you mean?
				Re: I2
				Posted: Wed Feb 17, 2016 3:49 am
				by Beniamino
				The listing says Prusa Mendel RepRap 3D-Printer
				Re: I2
				Posted: Wed Feb 17, 2016 8:28 pm
				by Mark
				this one is similiar to the I3 series, you can refer to the user manual for the I3X here to set up it:
http://www.geeetech.com/unassembledgeee ... p-941.html
And note that you need to use the corresponding firmware and also you can calibrate it according to this tutorial:
http://reprap.org/wiki/Triffid_Hunter%2 ... tion_Guide
				Re: I2
				Posted: Thu Feb 18, 2016 4:38 am
				by Beniamino
				Thanks. It came fully assembled. Does this change anything as far as what I need to do first?
				Re: I2
				Posted: Thu Feb 18, 2016 4:30 pm
				by Mark
				that would be better, just make sure the wirings are all correct and start to calibrate it!
				Re: I2
				Posted: Fri Feb 19, 2016 10:52 am
				by Beniamino
				I appreciate all this. I will try the calibration but I am still not sure what to do first. I know that I need to connect the Arduino card, and I have used the IDE with Arduino Uno and Nano (maybe it was Mini) but this card does not do anything when I plug it in, and I can't get the IDE to support it. Am I using the wrong program?
Ben
				Re: I2
				Posted: Fri Feb 19, 2016 9:45 pm
				by Mark
				don't quite familiar with your mother board, seems like a printboard? check out this link:
http://www.geeetech.com/wiki/index.php/Printrboard
				Re: I2
				Posted: Sat Feb 20, 2016 8:54 am
				by Beniamino
				Thank you, Mark, and you are correct that it is the Printrboard. This page then shows the Arduino IDE with some board choices that I don't have.
I'm not sure how to update the IDE in this manner. I downloaded Sprinter, but I just see some .h and .cpp files; I'm not sure how to use these to update my IDE.
Ben
				Re: I2
				Posted: Sat Feb 20, 2016 2:41 pm
				by Mark
				check out this reprap wiki link for the firmware loading part:
http://reprap.org/wiki/Printrboard
And note that "All preassembled Printrboards come pre-loaded with a bootloader and firmware. ", so you if your LCD is displaying the correct info, then maybe you don't need to reinstall the firmware.
