Issues with new build
Posted: Thu Mar 10, 2016 1:01 am
by PepperBuddha
Submitted to support twice now. No response in two weeks!
While assembling printer I found a broken part:
LCD frame holder NO.A19
Also found both L410mm smooth rods, No.3, to be oversize. Sorry I do not have a metric caliper. L410mm rods are .314 inch. All other smooth rods are .311 inch. At .314 inch the L410mm rods will not go into the X-axis idle end or X-axis motor end. The L410mm rods just barely fit into the Linear Bearings of the X carriage. They are so tight the rods do not turn in the bearings.
Walter
Re: Issues with new build
Posted: Sat Mar 12, 2016 11:11 am
by Mark
then you need to contact the sales to get the replacements.
Posted: Fri Oct 14, 2016 3:40 pm
by Lami René
Hello PepperBuddha,
Excuse me, I use Google Translator to translate the text of the forum in French, because I'm not bilingual. Thank you for your understanding and indulgence! This is William Kwok, a forum moderator suggests me to proceed in this manner.
Is that your problem is now solved?
If so, how have you solved the problem?
If not, what are your needs and expectations?
I bought a 3D printer Geeetech Rostock 301 (waiting to receive it) and I am informed about it. The suite is in French to reduce inconsistencies multiple translations ...
The friend René
Bonjour PepperBuddha,
Excusez-moi, j'utilise Google Translator pour traduire les textes du forum en français, car je ne suis pas bilingue. Merci pour votre compréhension et votre indulgence ! C'est William Kwok, un modérateur du forum qui me suggère de procéder de cette manière.
Est-ce que votre problème est maintenant réglé ?
Si oui, comment avez-vous réglé le problème ?
Sinon, quels sont vos besoins ou attentes ?
J'ai acheté une imprimante 3D Geeetech Rostock 301 (en attente de la recevoir) et je m'informe à son sujet. La suite est en français pour réduire les incohérences des traductions multiples...
L'ami René
