Auto Bed Levelling on M201 ?
nazario
Post by nazario »
May I instal an auto bed levelling on my M201 ?
Hardware and Firmware support this feature ?
Tnks
Re: Auto Bed Levelling on M201 ?
the hardware, I think you can connect the sensor to the endstop connectors, but there's no firmware to use, the firmware is not open sourced..
nazario
Post by nazario »
And is possible to use an other open source firmware on this printer (Repetier) ?
I want replace the extruder 2in1out with a one or two single extruder because I have had many problems with the extruder of the M201. Is this possible ?
Many tnks
Nazario
I have a firmware here, you can upgrade the M201 to a dual extruder printer like I3 pro C, just buy a MK8 dual extruder and replace the 2-in-1-out extruder, but note that your power supply for the GTM32 board is 24V, you might need to buy two 24V heaters for the dual extruder.
GTM32_DUAL.zip
(97.33 KiB) Downloaded 1128 times
nazario
Post by nazario »
Many tnks Mark
I will try this firmware
syossi2
Post by syossi2 »
hi
Can geeetech update the old firmware of this dual for m201 so it match to the new 1.0.5 ? with the new stepping?
thanks
yossi
printing 3D with M201 Geeetech
Benni94
Post by Benni94 »
I want it too!
daveapplemotors
Post by daveapplemotors »
I downloaded GTM32_DUAL.zip that someone kindly uploaded but it is an exe file.
Does an and anyone have ABL and two extruders working? I have converted my Geeetech Prusa i3 pro A to a dual extruder machine but ABL dosen't work.
claytonc2001
Firmware for GTM32 Rev A board installation
Post by claytonc2001 »
I had this firmware installed and working. However, I stupidly shorted some wires and had to get a replacement. My original board was a rev B. They sent me a rev A as a replacement board for $50. The problem is that this REV A board does not have the jumpers on it to allow me to flash the GTM32_DUAL firmware to it. From what I read there is a sort of adapter I would have to get to program the board.... Is the REV A board a step backward? Is there a way around this way of updating the board?
As far as I know, you should use the ST-LINK to upload.
viewtopic.php?f=20&t=17173
