MKS TMC2100 stepper motor driver
Is it possible to use these on the control boards supplied with Geeetech printers ?
Re: MKS TMC2100 stepper motor driver
Are they compatible with A4988? If so you can use it on the board I think.
neoprogger
They are compatible.
Do I need to adjust any voltage?
According to http://blog.gummibaer-tech.de/tmc2100-s ... olu-a4988/
it is not needed.
Thanks !
it is not needed.
Thanks !
neoprogger
Update: Just replaced 3 of my Drivers.
in spreadCycle Mode they produce a lot of noise when powered with 12 volts.
The StealthChop works perfectly. Just remove all 3 jumpers and dont connect pin conf1-3.
Voltage is adjusted to 0,6V, works just fine.
Nearly noiseless running now.
Thanks for sharing.
