Prusa i3 pro B, Y Axis motor issue, blocking in one way
Amoretti
Post by Amoretti »
Hi i just purchased a prusa i3 pro B and i'm experiencing a problem,
Everything went well building it, and everything is working fine when i'm using the users commands, but when i'm printing after a short moment the y axis motor only move in one way and instead
of moving in the other way it is vibrating, i already tried to resolve it by changing the voltage but it seems that it isn't the issue.
Does anyone have experienced the same problem ?
I would love some help here =)
Admin
Re: Prusa i3 pro B, Y Axis motor issue, blocking in one way
Post by Admin »
If every works well when you using manual control, please check your slicing
Amoretti
Post by Amoretti »
Hi, first of all thank you for your fast aswer,
I tried 2 diffrent slicer and it dosn't change anything, but i figured that when i'm playing a little while longer with the motor
using the users comand it does the exact same thing, could the A4988 defective ?
Admin
Post by Admin »
you can refer to this post for troubleshooting
agelos
Post by agelos »
have you find any solution yet?
I have the same problem
I Will check links provided in the morning.
