I3 Pro B X and Y rods
Posted: Tue May 31, 2016 8:16 am
I found when building my Pro B that the documentation says to use the 390mm smooth rods for the Y axis and 410mm rods for the X axis.
These should be the other way around. If they are not swapped the Y axis only has 180mm of travel.
Other than that the build was quite easy and I am very pleased with the results of the prints.
