the filament does not go down because the engine is not running down. when I change the direction of rotation , the engine is running up.
my tension on the card is 0875 V.
what's the problem ?
no problem with 3m test filament, now it no longer works.
thank you
i3 Pro C double extrudeur MK8 - carte GT2560 avec 5 A4988 ==> since 8 days.
My extruder damage the filament
i3 Pro C double extrudeur MK8 - carte GT2560 avec 5 A4988 - lit chauffant
Re: My extruder damage the filament
Hey,my friend.You can try the following instructions,that may be helpful.
