g2s pro lcd keypad
Posted: Fri Jun 10, 2016 5:21 am
by Fred77
I've got a little problem with a LCD on a G2s pro.
When i start the printer the LCD screen is Ok, everything works (I can see temperature ect, ect) , i can click on the knob and saw the menu but when I start turning the knob the display become crazy and show strange caracters.
the only way to get it back working is to reset the printer.
Any suggestion ?
Re: g2s pro lcd keypad
Posted: Fri Jun 10, 2016 11:46 am
Fred77 wrote:Hi,
Any suggestion ?
Hi,Fred
first,you can swap the wire behind the LCD control panel with another new one,then if it doesn't help yet,upload the corresponding firmware once again.
Posted: Fri Jun 10, 2016 1:18 pm
by Fred77
Thank you,
I"ll try to change the wire, do you know where i can get brand new one ?
Posted: Fri Jun 10, 2016 4:52 pm
Fred77 wrote:Thank you,
Dear Fred,
Maybe you could check the circuit related to LCD like the LCD control panel and the motherboard,and ensure there is the phenomenon of short-circuit.If there is not,then upload the corresponding firmware once again.If it all doesn't work,you can try to change the wire finally.
