Printer would not connect after updating to 1.0.5 firmware
Edvash
Post by Edvash »
the firmware was successfully updated, it works as a standalone, however , i can't connect it to the PC anymore
any suggestions?
Edan
Re: Printer would not connect after updating to 1.0.5 firmwa
Edvash wrote:Printer would not connect after updating to 1.0.5 firmware
any suggestions?
Edan
Hi,Edvash
Has your devices manager detected this?If it has,you must choose the corresponding "COM" port in your slicer software.
If hasn't,you can try to change a USB port or a USB wire,that may work.
If all above have done and it doesn't work,i'm afraid you'd better return to the firmware you used before.
