Y axis DRive not working
Posted: Mon Jun 27, 2016 4:01 am
by robguiri
Hi, I just built my first I3 pro B, My axis motor working fine and then stopped, the motor works in the x axis slot on the board, i am assuming that the slot on the board is broken, is it posible to reprogram the pins from my empty 2 extuder slot to funcion as the y axis?
I am new to this and would apreciate any help.
Re: Y axis DRive not working
Posted: Mon Jun 27, 2016 10:40 am
robguiri wrote:Hi, I just built my first I3 pro B, My axis motor working fine and then stopped, the motor works in the x axis slot on the board, i am assuming that the slot on the board is broken, is it posible to reprogram the pins from my empty 2 extuder slot to funcion as the y axis?
I'm afraid that may not work.You can swap it with the pins from X axis to check it the slot if it is broken or not.
Posted: Mon Jun 27, 2016 6:24 pm
by robguiri
Hi when I turned on the printer this morning the Y axis worked fine for about 5 Minutes then stopped again. Could this be a voltage problem?
Posted: Tue Jun 28, 2016 2:23 pm
robguiri wrote:Hi when I turned on the printer this morning the Y axis worked fine for about 5 Minutes then stopped again. Could this be a voltage problem?
It's possible.You can refer to this:
http://www.geeetech.com/forum/viewtopic.php?f=17&t=1703
