Page 1 of 2
Cant upload my firmware
Posted: Sun Sep 25, 2016 3:49 pm
by pootis_owner
Hi there i have the prusa i3 pro b and want to install the 12864 lcd panel but if i want to upload the firmware i cant verify it gives an error what can i do about it.....
Re: Cant upload my firmware
Posted: Mon Sep 26, 2016 6:23 pm
pootis_owner wrote:Hi there i have the prusa i3 pro b and want to install the 12864 lcd panel but if i want to upload the firmware i cant verify it gives an error what can i do about it.....
What Arduino version are you using?Try Arduino 1.0.1:
https://www.arduino.cc/en/Main/OldSoftw ... ases#1.0.x
Posted: Tue Sep 27, 2016 11:17 pm
by pootis_owner
I have got it the new arduino works but i have uploaded my marlin firmware to work with the full graphics controller with the u8glib files but it isnt working just beeping and flashing..... but the 2004lcd works just fine.... what do i wrong??
Posted: Wed Sep 28, 2016 10:26 am
by Toy
There's difference setting for 12864 and 2004 in firmware,
Refer to this link:
http://www.geeetech.com/forum/viewtopic ... 23&t=17040
Posted: Thu Sep 29, 2016 3:33 pm
by pootis_owner
I have tryed the link that you send me but not working i have tryed the other cables but only flashing and beeping.. cant get it to work
someone knows the problem??
Posted: Fri Sep 30, 2016 11:06 am
by Toy
You can try the firmware for A pro which uses the LCD12864,
see if it works.
http://www.geeetech.com/forum/download/file.php?id=2100
Posted: Sat Oct 01, 2016 3:21 am
by pootis_owner
ok i will give it a try but do i need to add the u8glib files? and do i need to change anything??? steps per mm??
Posted: Sat Oct 01, 2016 4:43 pm
by pootis_owner
I have tryed the pro a firmware then the screen isnt doing anything..... not light nothing
Posted: Tue Oct 04, 2016 3:27 pm
pootis_owner wrote:I have tryed the pro a firmware then the screen isnt doing anything..... not light nothing
Did you add the U8glib files when you compiled the firmware?And did it compile successfully?
Posted: Fri Oct 07, 2016 5:46 pm
by pootis_owner
I have added u8glib and then compiling it and then upload but it is not working....
