Extruder thermistor not working
trencapins
Post by trencapins »
I received the Prusa X and I have finished the assembly. The machine seems to work fine except for the extruder thermistor. This thermistor is not working. I have checked it is not a problem of the electronic board, since it works fine if I connect instead the hot bed thermistor.
I can see the broken wire.
Commercial assistance has asked me to post my problem in this forum
Re: Extruder thermistor not working
Could you take a picture of it and the status of LCD?
And have you tried fixing it?
trencapins
This is an image of the LCD screen. Please, note temperature is zero
trencapins
And in the following video you can see the thermistor fails, there is a wrong crimping of the wire:
https://drive.google.com/file/d/0B6CRDY ... sp=sharing
The thermistor cable is too loose,which make the thermistor has no a good connection to the heating block,and you can tighten it with tape.
