Problem with X axis on i3 pro b
Posted: Sun Oct 30, 2016 11:48 pm
by jauffrey
hello,
i reverse the x motor sens in marlin because the motor turn in the wrong sens and now the homing is good on the 3 axis but when i try to print a piece the printer try to print in -x and hit the x endstop but the orther axis work well, i can't find what is the problem
Sorry for the english i'm french
Best regards Jauffrey
Re: Problem with X axis on i3 pro b
Posted: Mon Oct 31, 2016 10:21 am
Hi,Jauffrey
Sorry what exactly do you mean by "when i try to print a piece the printer try to print in -x and hit the x endstop but the orther axis work well",you mean the printing is not in the center of the heatbed?Have you centered the object when you add it to the software and did you set it correctly in printer settings as follows:
http://www.geeetech.com/forum/viewtopic ... 819#p27819
Posted: Mon Oct 31, 2016 2:02 pm
by jauffrey
I found the solution i reinstall repetier host and now the piece is print in the center of the heatbed and before the piece was peinted on the axis x
Thanks for you message William
Posted: Mon Oct 31, 2016 2:24 pm
So what version is before and now?
Posted: Mon Oct 31, 2016 9:48 pm
by jauffrey
Before is the repetier host 1.6.0 give in the geeetech manual instruction and now the repetier host 1.6.2
best regard Jauffrey
