Extruder Problem Prusa I3 Pro B
Posted: Thu Nov 10, 2016 1:25 pm
I have a lot of Problems with the extruder. After the buying he doesn't work.
He makes sounds like Clogging.
https://youtu.be/641iKPCryQY
I have checked the Inliner thats was not ok but a correct doesn't fix the problem
http://i.imgur.com/xcrMYcj.jpg
i have tested various Nozzle
i have tested various filament gear
I have make mor prressure but it don't helps
https://youtu.be/flBJIXbPp10
it stops an need more pressure at normal extruding.
more pressure isn't possible because the arm was on max psosition and with more waschers i dont can mount the spring.
The nozzle isn't clogged. i hav make the test like (http://www.geeetech.com/forum/viewtopic ... 19&t=17097)
