PrusaI3 pro C dual - no connection via USB
Posted: Fri Nov 11, 2016 7:11 am
hello there,
i just bought my very printer and managed to build it up without bigger problems.
i also was able to start a printing job from the SD-Card. sadly the bed adhesion wasn't enough, so the result was a mess - but the mashine works
my main issue is, that my win7 (32bit) is not able to connect to the printer.
what i did:
1) drivers were successfully installed, when i plugged the USB in
2) i doubble checked it in the system control panel (german: "Gräte-Manager"). both entrys are fine
3) i installed the repetier software and tried to configure it as in the manual written:
https://www.geeetech.com/Documents/Prus ... manual.pdf
i am using the highest COM (COM3 in my case, and btw the only one visable). and then i wanted to connect to the printer.
...they say "it just works." but it doesn't.
4) i started the repetier server web interface, configured the printer with the same specifications - same result.
5) reboot didn't help
any suggestions?
what i did:
any suggestions?
