Fan for extruder
terrace_dr
Fan for extruder
What is the yellow wire for..Because i need to replace the fan and I have only a two wire 12v fan.
Can i use a two wire fan? Thanks
Re: Fan for extruder
The yellow wire is for the tacho output. If connected via a resistor to the +ve supply it will give two pulses per revolution of the fan. It can be used to detect the fan speed or just to ckeck that the fan is working. I don't know if your control board uses it but if it does it will signal an error if it's not present.
Russell.
Russell.
terrace_dr
Thanks. I have the GT2560 board on the i3x prusa.
Do you know if this board uses these pulse signals?
Sorry, I don't know if it is used. It shouldn't do any harm to try it and see.
Russell
Russell
terrace_dr
The post above has absolutly noting to do with the question from the OP.
Good grief
Good grief
Hi @terrace_dr,
You can use the fan if it is one with 12V,and make sure you have the right wiring to the 2 pins("+" to "+" of the connector on the board,and "-" to "-").
terrace_dr
Thank you for the help!
daveapplemotors
I have a two wire fan and the display shows the percentage of fan speed just as it did with a three wire fan.
