Page 1 of 2
extruder clog how does the warranty works
Posted: Mon Dec 05, 2016 7:55 pm
by jjcchhrr
after a lot of assembly and disassembly to unclogh the extruder
the temperature probe has ended up breaking I think.
I now have systematically have a message of error.
i ve never been able to extrude more than a 0.5cm of PLA always a clogh
I tried to extrude at different temperatures and diferent filament of planothing
the ring in ptfe a Ended up starting to burn and now nothing can be down i have to change the m6 pipe throat with ptfe and the nozzle...
very disappointed!!!
Re: extruder clog how does the warranty works
Posted: Tue Dec 06, 2016 2:30 pm
What model is your printer?Did you use the ejector pin to clear the clogging?
Posted: Tue Dec 06, 2016 2:33 pm
by jjcchhrr
No answer?
Posted: Tue Dec 06, 2016 5:05 pm
by jjcchhrr
I watch the videos on the forum and yes i use the pin
Prua i3 pro b acrylic
Posted: Wed Dec 07, 2016 2:52 am
by jjcchhrr
a solution to solve my trouble?
Posted: Wed Dec 07, 2016 12:17 pm
by jjcchhrr
still impossible to male any try and not even the beginning of a solution
Posted: Wed Dec 07, 2016 5:46 pm
Could you take a picture of this part you mentioned?
"the ring in ptfe a Ended up starting to burn and now nothing can be down i have to change the m6 pipe throat with ptfe and the nozzle..."
Posted: Thu Dec 08, 2016 2:04 am
by jjcchhrr
The burnt ptfe ring (you can see which ring i m talking about on this Picture
https://www.google.fr/search?q=ptfe+thr ... Cw#mhpiv=8
is in the bin since last week end
It has been replace by the one at the entry of the stepper motor of the mk8 to make new tries came from the entry of the stepper motor
You can see on the Picture 2,3,4,5 and 6
http://m.ebay.fr/itm/Duty-free-Extrudeu ... nav=SEARCH
what i need is this and your description of the the product correspond to my trouble
https://www.geeetech.com/mk8-extruder-h ... -1012.html
i dont know what is the original problem of clogh trouble of barrel, touble of nozzle
but as i explain assembly and dis assembly finished by breaking the thermistor wire
so what i need as spare part is this
Posted: Thu Dec 08, 2016 11:09 am
I mean you can attach the picture of your broken parts(on your own printer),not the picture on the Internet...
Concerning the spare part,maybe you can talk to your seller.
Posted: Thu Dec 08, 2016 1:19 pm
by jjcchhrr
