G2S Pro problems with extruder motor one.
Posted: Sat Dec 10, 2016 2:34 am
I just finished building my G2S pro, and have a problem with the connection to extruder motor one. I'm pretty sure that the cable and the motor
itself is fine, because i tried to switch with the one from motor two and then i worked, so the problem is in some settings or in the connection on the board itself. What happens is when I activate the motor connected to the "Extruder one motor" socket on the board, it just buzz'es for the amount of time is was set to be running, but the drive wheel do not move.
I hope some one can help with a fix for this, because a "working" extruder one motor I'm pretty lost!
