M301 Printer supported g-code commands list
Posted: Thu Dec 15, 2016 2:24 am
Is there a list available of supported g-code commands for the M301 firmware? (Preferably with descriptions/notes)
Thanks.
--Dave
Thanks.
--Dave
http://forum.geeetech.com/
Code: Select all
* Implemented Codes
* "G" Codes
* G0 -> G1
* G1 - Coordinated Movement X Y Z E
* G10 - retract filament according to settings of M207
* G11 - retract recover filament according to settings of M208
* G28 - Home one or more axes
* G90 - Use Absolute Coordinates
* G91 - Use Relative Coordinates
* G92 - Set current position to coordinates given
* "M" Codes
* M17 - Enable/Power all stepper motors
* M18 - Disable all stepper motors; same as M84
* M20 - List SD card
* M21 - Init SD card
* M23 - Select SD file (M23 filename.g)
* M24 - Start/resume SD print
* M25 - Pause SD print
* M92 - Set axis_steps_per_unit - same syntax as G92
* M104 - Set extruder target temp
* M105 - Read current temp
* M106 - Fan on
* M107 - Fan off
* M109 - Sxxx Wait for extruder current temp to reach target temp. Waits only when heating
* Rxxx Wait for extruder current temp to reach target temp. Waits when heating and cooling
* IF AUTOTEMP is enabled, S<mintemp> B<maxtemp> F<factor>. Exit autotemp by any M109 without F
* M114 - Output current position to serial port
* M115 - Capabilities string
* M117 - Display a message on the controller screen
* M119 - Output Endstop status to serial port
* M140 - Set bed target temp
* M190 - Sxxx Wait for bed current temp to reach target temp. Waits only when heating
* Rxxx Wait for bed current temp to reach target temp. Waits when heating and cooling
* M220 - Set speed factor override percentage: S<factor in percent>
* M300 - Play beep sound S<frequency Hz> P<duration ms>
* M301 - Set PID parameters P I and D
* M304 - Set bed PID parameters P I and D
* M500 - Store parameters in EEPROM
* M502 - Revert to the default "factory settings". You still need to store them in EEPROM afterwards if you want to.
* "T" Codes
* T0-T3 - Select a tool by index (usually an extruder) [ F<mm/min> ]
