Stepper motor getting toomuh heat
shiva
Post by shiva »
I replaced Stepper drive for my I3ProX.My all stepper motors getting too much heat about 70c if I run continue 45 minutes .I cant touch that.What is problem how to correct it?
If it is problem of current(I am using A4988) how to adjust and what current output should go to each stepper?
Shiva
Cup
Re: Stepper motor getting toomuh heat
Post by Cup »
shiva wrote:Hi
Shiva
Hi,Shiva
Sounds impossible...Such a high temperature(70c)!
You'd better check the voltage on driver A4988:
viewtopic.php?f=17&t=17038
shiva
Post by shiva »
I have check voltage as shown in your link.It shows 5.3volt and 11.9 volt.I think some other problem.
