Geeetech i3 pro c dual extrusion problem
Posted: Sun Feb 19, 2017 2:54 am
by Marc71
Does someone have any idea why the following happens ? It seems to be printing the first layer correct then it moves left print some then left again. see picture
- dual extruder.png (1.16 MiB) Viewed 14515 times
Re: Geeetech i3 pro c dual extrusion problem
Posted: Sun Feb 19, 2017 11:31 pm
by cosmith
Is the X belt slipping? Problem with the servo? Settings issue with the travel speed? That's a strange problem.
Can you attach the GCode file so I can try it?
--Colin
Posted: Mon Feb 20, 2017 3:00 am
by Marc71
looks like it is an issue with the X-axis (slips) it is not advancing correctly not sure if something wrong here DEFAULT_AXIS_STEPS_PER_UNIT {85.3333, 85.3333, 2560, 158.8308}. the belt seems ok not to tight
i included the configuration.h file maybe you can have a look and tell me what is wrong
https://drive.google.com/drive/folders/ ... sp=sharing
Posted: Mon Feb 20, 2017 3:34 am
by cosmith
The configuration looks OK, except the 158 for the E axis seems high. That shouldn't effect the X axis though. Maybe the belt is too loose, or there is a problem with the stepper driver? There is a way to test the voltage, it's on the forum here somewhere. You can also swap out the stepper driver with one of the other ones and see if it makes a difference.
Posted: Mon Feb 20, 2017 3:45 am
by Marc71
What would you recommend as a setting ?
Posted: Mon Feb 20, 2017 4:47 am
by cosmith
You will need to calibrate it to get the correct value.
https://www.youtube.com/watch?v=YUPfBJz3I6Y
Posted: Mon Feb 20, 2017 10:29 am
by Marc71
Ok so i found the problem. It seems that the double extruder is a bit going toward the front ( fan). Whenever i lift toward the back it then works ok for a minute but then it start sjipping steps. Any recommendations ?
Posted: Mon Feb 20, 2017 6:54 pm
by cosmith
Can you post a video?
Posted: Thu Feb 23, 2017 8:00 pm
by Marc71
Sorry for the late response.
so now the printout sticks ok to the plate, starting to print ok then slowly shift to the left. please check the video and let me know what you think.
https://youtu.be/GSIhXKMd6oQ
Posted: Sat Feb 25, 2017 10:22 pm
by Marc71
Driver module was defected I replaced and all ok for now. will do more testing.
Thank you all especially to Geeetech support with the idea to switch between modules.
