3d touch
tpc1506
3d touch
Post by tpc1506 »
hi I have bought the 3d touch and the gt2560A+ board for my i3 pro everything has been installed following the manual but now my y axis is not working correctly it starts its auto level process and then just jams the bed all the way forward and then all the way back and I have to emergency stop my printer how can I fix this.
it was working fine with this board to make the mount for the 3d touch but since I downloaded the firmware from geeetech and then changed what was need from the manual it dosnt work.
thank in advance for your help
Re: 3d touch
hi, there's something you need to know before using 3D Touch.
viewtopic.php?f=27&t=18371
tpc1506
Re: 3d touch
Post by tpc1506 »
thanks William
but my probe points still not right it keeps going off the board and I have to e stop where can I change this
or can you post copy of completed firmware for i3 pro b with 2560 rev a+
thanks
cosmith
Re: 3d touch
Post by cosmith »
What kind of leveling are you using (linear, 3 point, bilinear) and what are your probing points? It may be trying to probe an area it can't reach.
Re: 3d touch
I know the link where you can download the firmware of all versions.
viewtopic.php?f=20&t=17046
