I have been printing for a while with 3D Touch. It works well. I am trying to get 3Dtouch to function with Pi3a Pro2 firmware--for dual nozzles-- from viewtopic.php?f=20&t=17046
I modified Pi3a pro's configuration.h file much like my PI3A_Pro but it doesn't deploy the sensor in the middle of G28--safe home to center.
Pi3a pro-- works fine ABL is reliable with 3Dtouch--single nozzle
Pi3a pro2 -- both extruders, temp sensors and heaters work but there is no control of 3D touch. M280 commands don't work. Otherwise I think it would be right.
Below are the only changes in configuration.h from Pi3a pro to Pi3a pro2--the recommended dual extruder firmware.
FROM Pi3a pro--:
#define EXTRUDERS 1
//#define EXTRUDER_OFFSET_X {0.0, 20.00} // (in mm) for each extruder, offset of the hotend on the X axis
//#define EXTRUDER_OFFSET_Y {0.0, 0.00} // (in mm) for each extruder, offset of the hotend on the X axis
TO Pi3a pro2:
#define EXTRUDERS 2
#define EXTRUDER_OFFSET_X {0.0, 20.00} // (in mm) for each extruder, offset of the hotend on the Y axis
#define EXTRUDER_OFFSET_Y {0.0, 0.01} // (in mm) for each extruder, offset of the hotend on the Y axis
AND
FROM Pi3a pro--:
#define TEMP_SENSOR_0 1
#define TEMP_SENSOR_1 0
TO Pi3a pro2:
#define TEMP_SENSOR_1 1
FROM Pi3a pro--:
#define LEFT_PROBE_BED_POSITION 15
#define RIGHT_PROBE_BED_POSITION 195
#define FRONT_PROBE_BED_POSITION 61
#define BACK_PROBE_BED_POSITION 190
#define X_PROBE_OFFSET_FROM_EXTRUDER -5 // Probe on: -left +right
#define Y_PROBE_OFFSET_FROM_EXTRUDER 56 // Probe on: -front +behind
#define Z_PROBE_OFFSET_FROM_EXTRUDER -3.30 // -below (always!)
TO Pi3a pro2:
#define LEFT_PROBE_BED_POSITION 21
#define RIGHT_PROBE_BED_POSITION 180
#define FRONT_PROBE_BED_POSITION 70
#define X_PROBE_OFFSET_FROM_EXTRUDER 20 // Probe on: -left +right
#define Y_PROBE_OFFSET_FROM_EXTRUDER 70 // Probe on: -front +behind
Both Pins.h files are identical between pro2 and pro. I checked conditionals.h and configuration.adv.h too. Identical. Is there another FW to get ABL to work?
version preference and config file?
Re: version preference and config file?
Firm ware is the gree tech ratio with the preference of the life and stages in sections of the society for the movies. The entertainment value of the torrent is cited for the fulfillment of the boom essays reviews objectives in life and sharing is done for the punctuation of the torrent in different ambits for the candidates.
Stuart, Florida jumps are not for the starting jumper. Perceivability is low, the huge stone reef framework starts about three miles seaward at profundities of sixty to 65 feet, and the outer edges are at profundities of how to make Water purification 120 to hundred and sixty feet. Less jumpers mean an enormous assortment of fish and beast lobster, yet take this with a neighborhood Plunge Expert.
