Power Supply Problem with Prusa i3 Pro B
Posted: Tue Mar 21, 2017 3:53 am
I bought on 24.11 the printer and since then not much printed (about 1kg PLA).
I wanted to start a new print, but I could not do it successfully.
The printer was connected via USB and showed everything on the display.
The repetition software ran perfectly and could also be connected to the printer.
Only the print could not be started.
Then I pulled out the USB cable and the printer went out.
The LED of the power supply glowed green and the power switch also lit.
Then I looked at the cable on the circuit board and had the result as seen in the pictures.
The printer is not even half a year old... so please help me
This is very frustrating....
Regards
Tobi
Regards
Tobi
