Unable to connect Rumba Board to PC
Posted: Thu Apr 13, 2017 7:42 pm
I just purchased a new Rumba board a few days ago, I uploaded Marlin to it and everything was working fine.
A few days later, I decided to upload a modified version of Marlin but i couldn't get to connect the Rumba with my PC (the light Tx and Rx stayed "on" all the time).
I tried to set the power jumper in "USB powered" position, then placed a jumper slightly on the two pins Reset and Ground, connect the USB (the Tx and Rx light was off) but when i took out the jumper from the reset, the les Tx and Rx came back continuously on.
I tried with different USB cables (i have another Rumba board which is working just fine with my computer and the same usb cable) and i even tried to solder a new cable to the 4 pins usb next to the mini usb without any luck...
I'm out of idea
, so if someone could help me, i would be very greatfull!
Thanks!
I'm out of idea
Thanks!
