MeCreator 2 Issue
Posted: Wed Apr 26, 2017 1:11 am
by Viniciusrn
I bought the printer and I have an annoying problem.
The panel is crazy, as if the button was being pressed all the time, see the video:
https://www.youtube.com/watch?v=lAveMjLeJZQ
Because of this problem I can not print from SD.
* I have already disassembled and made sure that all cables are properly connected
* Updated the firmware
The seller (Banggood) asked to report the problem in this forum.
can you help me?
Re: MeCreator 2 Issue
Posted: Thu Apr 27, 2017 5:29 pm
Hi,I think you can change the cable between LCD and motherboard.
Posted: Fri Apr 28, 2017 6:17 am
by Viniciusrn
Turning ON only the motherboard without the LCD cable I can still hear the clicks of menu.
I believe the problem is on the motherboard.
Posted: Fri Apr 28, 2017 10:26 am
Viniciusrn wrote:Turning ON only the motherboard without the LCD cable I can still hear the clicks of menu.
Hi,I guess the firmware you have upgraded also may have problems.So I need to know which version of firmware do you upgrade and which software are you using to do that,Arudino1.0.1 or Easyprint?
As to the board,could you take a video showing the working of board when power is on and some pictures which have unplugged all connections?
