				replace extruder
				Posted: Mon May 01, 2017 5:46 pm
				by Jeroen
				Hi, I have an Aluminum Prusa I3 3D Printer with an MK8 extruder and would like to replace it with an extruder with higher print quality. Which extruder is eligible for this? Do I have to make firmware modifications? If so, where can I find this? How do I do this?
I know many questions but possibly someone can help me.
Thanks in advance.
				Re: replace extruder
				Posted: Wed May 03, 2017 5:06 pm
				Jeroen wrote:Hi, I have an Aluminum Prusa I3 3D Printer with an MK8 extruder and would like to replace it with an extruder with higher print quality. Which extruder is eligible for this? Do I have to make firmware modifications? If so, where can I find this? How do I do this?
Thanks in advance.
Hi,you can try replace it with this one:
https://www.geeetech.com/assembled-mk8- ... p-857.html.Not necessary to make firmware modifications.
				Posted: Mon May 29, 2017 4:37 am
				by Soadyheid
				What size of nozzle have you fitted to your extruder?  To get a higher quality print you would need to fit a smaller one and adjust the nozzle setting in your slicer program.  The nozzle size is marked on the nozzle itself.
You shouldn't need to replace the whole extruder if your current one prints OK.
Check Amazon for Nozzles:
https://www.amazon.co.uk/s/ref=sr_pg_2? ... B01KHNFVOE
For instructions how to change the nozzle search  Google or YouTube.
Note that with a smaller nozzle, your prints will have more layers and therefore take longer to print.
Play Bonny!
Soadyheid
