Hello everyone, i have a Geeetech Aluminum Prusa i3 and i have a problem with my extruder it stoped extruding after like 15 prints
so i did a couple of things to try to resolve the problem: (THE X Y AND Z AXIS WORKS NORMALLY )
-replaced the entire extruder with a new one
-replaced the hot end
-swaped the extuder motor with the X axis motor and i kept the hot end wired to the board (the X axis motor kept doing the same thing as the extruder motor BUT the extruder motor worked normally SEE THE VIDEO)
-changed the cable that connect the extruder motor to the board
-swaped the extruder driver with the Y axis driver
-turned the screw on extruder driver
-used usb cable instead of the memory card for printing
-changed the fan to a bigger one
-changed the software that i use from cura to repetier (and i couldn't connect my printer to cura maybe you can help me with that)
and i still have the same problem now i have no idea what to do. the problem could be from the board or the power supply maybe and the hot end works normally and the problem is not from the extruder the weird part is that when i extrude using the LCD it works normally
i've made a video of the printer maybe it will help identifying the problem and i've uploaded cura and the printer settings and a picture of the board
thank you and sorry for my bad english
https://www.youtube.com/watch?v=5dynISHJcMw
http://imgur.com/gallery/qFabh
weird Extruder problem
omaarben12
Jump to
- Firmware
- 3D Printer
- ↳ Thunder
- ↳ Mizar Pro
- ↳ Mizar S
- ↳ Mizar
- ↳ Geeetech I3 Pro B
- ↳ Geeetech I3 Pro W
- ↳ Geeetech I3 Pro X
- ↳ Geeetech I3 Aluminum
- ↳ Geeetech I3 Aluminum Pro
- ↳ Geeetech I3 Duplicator 5
- ↳ Geeetech I3 Pro C
- ↳ Geeetech I3 M201
- ↳ Geeetech A10 Series
- ↳ A10T
- ↳ Geeetech A20 Series
- ↳ Geeetech A20
- ↳ Geeetech A20M
- ↳ A20T
- ↳ Geeetech A30 Series
- ↳ A30M
- ↳ A30 PRO
- ↳ Geeetech E180 Mini
- ↳ Geeetech MeCreator2
- ↳ GiantArm D200
- ↳ Geeetech Delta Series
- ↳ Geeetech DP200 Series
- 3D Printing Software
- ↳ Software
- ↳ Wifi Box
- ↳ Bug report
- ↳ Download
- Hardware
- ↳ 3D Printer Hardware
- ↳ Stepper Motor
- ↳ Control Board
- ↳ Extruder
- ↳ Hot bed
- ↳ LCD Panel
- ↳ Power Supply Unit
- ↳ Assembly
- ↳ Others
- Print Quality
- Resoures Sharing
- Feedback&Suggestion
- Project Talent Show
- Other Discussion
- ↳ Leveling Guide
- ↳ Open Hardware
- ↳ Mods And Hacks
- ↳ Products FAQ
- ↳ Tips & Tricks
- ↳ Discuss & Help
- ↳ Windows
- ↳ MAC
