Max Temp Errors - MeCreator 2-fixed
tjm3d_auto
Post by tjm3d_auto »
MeCreator 2
This thing has been working just fine but now I'm getting continuous 'ERR: MAX TEMP' errors as if there is no temperature control at all.
Any suggestions on what to look for? The numbers in the software are fine, the upgraded firmware v1.0.2 has the correct numbers for shutting down the heaters but it still overheats. In addition, the temperature oscillations are wild, going from about 225 to 298 degrees, back and forth and never settling down to the 250C that I've chosen to print ABS. I've done the PID tuning several times but it appears this is making no difference.
Suggestions?
thanks,
tony
Re: Max Temp Errors - MeCreator 2
I guess the thermistor error, so it is not correct on the temperature control.
tjm3d_auto
Thanks, that was my assessment.
Is the thermistor replaceable or fixed permanently in the hot end? Would this be a warranty issue, and if so, how do I get a replacement hot end with thermistor?
thanks,
tony
Thermistor is on the top of the extruder which hidden in the extruder and connects with red wire.
tjm3d_auto
Re: Max Temp Errors - MeCreator 2-fixed
Installed a new hot end (w/sensor) - $5.50 . Works perfectly.
Tony
good job.
