JHD204A LCD problem
Posted: Sun Apr 01, 2012 8:09 am
I have bought a JHD204A LCD (20 x 4) display, but cannot get the contrast to work .
I have wired pins 1 and 16 to -ve (ground), and pins 2 and 15 to 5Volts +ve - as specified in the data sheet.
Pin 5 (the Read/Write select) is connected to ground (-ve).
Pin 3 (Vee) is used to adjust the contrast - and is connected to the wiper of a 10K potentiometer (variable resistor - called a pot ). The other wires of the potentiometer are connected to -ve (earth) and 5V +ve.
I have measured the voltage on pin3, and by turning the pot the voltage is varied between 0 and 5v.
When the power is applied to the JHD204A, the backlight turns on, and rows 1 and 3 show bright pink/purple rectangles.
Turning the potentiometer has no effect on the display.
I have 2 different LCD displays that work correctly using this set-up, and the contrast can be adjusted on these LCDs.
As a further check, I connected the data lines of the JHD204A to my Arduino, and used the example code of "Hello World".
The only change I made to the code, was to alter the lcd.begin(16,2) to lcd.begin(20,4) - since the JHD204A is a 20 x 4 display.
No characters show on the JHD204A. The LCD remains the same as before when only power was connected.
I have 2 other models of LCD display that work correctly - using the same setup as above.
Is there some manufacturer change in the specifications or pins of the JHD204A, or a fault with the design of the JHD204A ?
I have searched the internet, and noticed other forum posts with the same problem using the JHD204A (eg contrast does not work).
Without the ability to change contrast, the LCD cannot be used as a display.
Any assistance greatly appreciated......................KP_OZ
