Extruder Heating Problem
Posted: Sun Aug 06, 2017 6:26 pm
by malp
Repetier Host does not start the printer but continually says "Heating Extruder". I'm trying to print ABS at 245C. The temperature monitor at the bottom of the panel shows the extruder temperature constantly fluctuating between 12 degrees below the set temperature to 3 degrees above. My room temperature is 36C (Spain). Do I have a problem with the heater or thermostat?
Re: Extruder Heating Problem
Posted: Wed Aug 09, 2017 2:39 pm
I guess you had better to upgrade the firmware or upload the firmware again due to the randomly starting heating.
Posted: Fri Aug 11, 2017 1:42 pm
by tjm3d_auto
Do a PID tune ( http://reprap.org/wiki/PID_Tuning ) and if that doesn't work install a new temp sensor.
