EasyPrint Slicer crash
Posted: Sat Dec 30, 2017 8:14 pm
by Bpz53
I use the last EASYPRINT version (1.1.7). I control by USB my E180 without any probs. When I load any STL file (e.G; the deer.stl demo file) it appears in the view zone. But when I try to slice it by clicking on "Slicer" a first window appears "Slicing panel" and immediatly another error message windows saying "EASYPRINT has stopped to run".
Any idea ?
Bernard
Re: EasyPrint Slicer crash
Posted: Tue Jan 02, 2018 5:03 pm
Could you uploading some pic of the issue?
Posted: Tue Jan 02, 2018 10:56 pm
by gadget.iom
I've had this happen a few times as well. It has required a restart of the software.
I will take some screenshots if it happens again.
Posted: Sun Jan 07, 2018 2:07 am
by Chuck240
Mine also fails continuously when trying to slice. Closed the program, restart, re install, nothing seems to make a difference. I'll post if I find a cure. Overall, this software for the PC and Mobile seems incredibly unstable.
Posted: Mon Jan 08, 2018 2:55 pm
Chuck240 wrote: Sun Jan 07, 2018 2:07 am Mine also fails continuously when trying to slice. Closed the program, restart, re install, nothing seems to make a difference. I'll post if I find a cure. Overall, this software for the PC and Mobile seems incredibly unstable.
What is your version number?
Posted: Wed Jan 24, 2018 4:37 pm
by auttila
EasyPrint 3D on Windows 10 is indeed always crashing. Debugging it with Visual Studio gives only this piece of information:
System.FormatException was unhandled
Message: An unhandled exception of type 'System.FormatException' occurred in mscorlib.dll
Additional information: Input string was not in a correct format.
Perhaps it is because I am using Finnish locale on my machine. I mean, decimal separator is comma, date format is DD.MM.YYYY and so on.
Any help with that would be appreciated.
Posted: Fri Mar 02, 2018 3:47 am
by Griffin
I have the exact same problem... for 6 mounth. Dont hope for a fix soon.
All they do is asking for pictures and then they stop replying.
Not verry good service...
Posted: Mon Mar 12, 2018 6:40 am
by carre82
After hours of tests I decided to forget about the easy print slicing function.
I do use SLIC3R open source and working perfect
Posted: Mon Mar 12, 2018 5:44 pm
carre82 wrote: Mon Mar 12, 2018 6:40 am After hours of tests I decided to forget about the easy print slicing function.
Thanks for your feedback!We will improve us software
