Wiring the 2 z-axis motors
Posted: Mon Jan 15, 2018 9:16 pm
by Janie Provis
Hi all,
I am very new to building anything like this so if someone can help I would be very grateful. I followed the instruction videos and have now got to the wiring section, it wants me to put both z-axis plugs into one socket, how do I do this couldn't see how this was achieved in the video.
I look forward to using the printer once I get past this problem.
Re: Wiring the 2 z-axis motors
Posted: Wed Jan 17, 2018 6:55 pm
You should refer to it
- GT2560A+.png (1.36 MiB) Viewed 8908 times
Posted: Wed Jan 17, 2018 7:32 pm
by _kaktus_
Beautiful cheat sheet.
Can I request a full specification for the GTM32 Pro VB?
Posted: Wed Jan 17, 2018 7:42 pm
- GTM32PRO VB.jpg (189.43 KiB) Viewed 8905 times
Posted: Wed Jan 17, 2018 8:33 pm
by _kaktus_
Thank you for sharing.
I know this drawing from the manual. It will be very useful in this form.
I am wondering the functionality of the connector of the described LED.
I do not know the functionality of a small ribbon cable FFC connector, a goldpin (4-pin), a micro switch, a multi-pin end stops connector.
In the latter, few are practically used and the rest?
Is it possible to connect limit switches in a larger number eg each end?
Has such functionality been programmed? The menu shows some options related to this ...
This information can be helpful to many users.
I hope I am understood because my English is very weak ...
Posted: Wed Jan 17, 2018 8:37 pm
by _kaktus_
And from the bottom there is still a slot for memory card ...
Can I use them for a purpose?
