Easyprint 3D slice problem.
Posted: Tue Jan 30, 2018 11:19 am
by Admin
If you are using Easyprint 3D to slice the file, and it shows like this.
"EasyPrint stopped working. The problem caused the program to stop running the System Windows program terminates to notify whether it is available"
Then you can download visual C++, here is the link.
https://www.microsoft.com/en-us/downloa ... x?id=48145
click download, If your compuoter is 32 bit, you need download "vc_redist.x86.exe"
If your computer is 64 bit, you need download them both.
Caution:you have to download one by one, first you need download "vc_redist.x86.exe", then after installing it, you need download "vc_redist.x64.exe"
then restart your computer.
Re: Easyprint 3D slice problem.
Posted: Tue Dec 25, 2018 7:12 am
by jhhill3dprinter
I had a problem with the updated version of 1.1.7. not slicing and giving me messages about not finding a gcode reference from my desk top icon. I went back to my 'all programs' list and clicked on my new Easyprint3d 1.1.7 version in that list. This opened up the application and then I tried it and it worked fine. This new version then started working fine on slicing from my desk top icon. It must have corrected the error in the app.
Posted: Sat Sep 05, 2020 8:29 pm
by elicy
[l\https://www.leads360.pk/][leads generation company] is the fastest way to generate leads for your business
Posted: Sun Sep 06, 2020 1:51 am
by Pavan355
If you are using Easyprint 3D to slice the file, and it shows like this. Then you can download visual C++, here is the link. If your computer is 64 bit, you need download them both.
Posted: Fri Jul 08, 2022 3:54 pm
by Wehner58
The Easyprint problem is a known bug that can occur when printing with the Easyprint 3D printer. The problem manifests itself as a series of horizontal lines or "slices" in the printed object. One of my friend told me this thesis services source to write on 3D printer. The cause of the problem is unknown but it is believed to be related to the software used to generate the print file. There are several workarounds for the problem but the most effective is to simply avoid using the Easyprint 3D printer.
