I'm having trouble setting up Marlin right for my Wanhao Duplicator i3 v2. About a week ago I had it setup to the point where it was working but only when it was hooked to the computer. Turns out it was my Arduino board so I bought anew one and now I'm not having the problems I was. I loaded the same setup that I did with my other one where it was working fine but whenver it is plugged into the computer or I just turn my printer on it says "KILLED. PRINTER HALTED Please Reset" I'm not quite sure what settings I need to change. I'm also having trouble figuring out how to make the dial move to select prints and what not. I know I have to change something in the "pins.h" file but I have no clue what. I am pretty new to this. I've attached my Marlin Config if anyone can help that would be greatly appreciated.
I'm using a RAMPS 1.4 board, Arduino Mega 2560, Wanhao Duplicator i3 V2 Marlin 1.1.6 and Ardunio v 1.8.3 and this is the display I bought: https://www.amazon.com/gp/product/B01B2 ... UTF8&psc=1
Marlin Setup for Wanhao Dup. i3?
Re: Marlin Setup for Wanhao Dup. i3?
1.It seems the wiring of thermistor install not correct
2.The pin define of thermistor may not correct
3.The type define of thermistor at Marlin may not correct
