Page 1 of 2
Fans slow down when extruder or hotbed activated
Posted: Tue Mar 13, 2018 11:29 pm
by JustinSB
Are both fans supposed to noticeably slow down when either the hotbed or the hotend are turned on & warming up? If I turn the hotend off, I can hear them instantly speed up too...?
It's really quite noticeable, & makes me wonder about my PSU? Is this normal?
Re: Fans slow down when extruder or hotbed activated
Posted: Wed Mar 14, 2018 7:22 pm
The speed of the fan up to max and when the printer power on?
Posted: Wed Mar 14, 2018 11:38 pm
by _kaktus_
I will say this:
a similar effect I once noticed in my model.
For me, this is due to a shortcoming in the design phase.
A small linear stabilizer must work hard. The result is its overheating.
Therefore, the element begins to limit its output power to prevent burning.
I will soon finish the new description: kaktus' guide - fans - appendix
It will be clearly exposed there what I am talking about now.
You have a different printer model (whose design I do not know), but I think the problem may have remained.
Wait patiently ;-)
I will present a simple solution. (workaround).
for me it is not a mistake but a simple oversight because of the lack of proper tests.
I warmly greet the entire Geeetech team. ;-D
Posted: Wed Mar 14, 2018 11:40 pm
by _kaktus_
Now I can advise you
Do not turn on all fans if it is not necessary. And if it is, turn it on for a short time.
Posted: Fri Mar 16, 2018 1:50 am
by JohnDeere630
Sounds like a weak power supply. I had the replace the PS on my I3 right off the bat; it only put out 8 volts.
Posted: Fri Mar 16, 2018 5:03 am
by JustinSB
I only have the stock motherboard fan on my Pro W, along with the 30mm fan on my E3D Lite6 hotend, as the E3D Titan extruder doesn't have a fan. They are both TWO wire fans, ie there's no speed controller, they are either full on, or off, & I can't work out how to turn them off.
I can't get them to stop when not in use in the firmware, as I just can't figure what settings to change in Marlin 1.1.7 stable Configuration_adv.h - I looked up the pins in pins_GT2560_REV_A_PLUS.h and pins_GT2560_REV_A.h where it said:
// Heaters / Fans
#define HEATER_0_PIN 2 // I assume this is Hotend 0
#define HEATER_1_PIN 3 // I assume this is Hotend 1 (unused)
#define HEATER_BED_PIN 4 // I assume this is Hotbed
#define FAN_PIN 7 // I assume this is the PWM that I should use for my part cooling fan, when I get one
so, in Configuration_adv.h, I changed this section to use the Hotend 0 pin
#define E0_AUTO_FAN_PIN 2 // (was originally -1)
But alas, it did nothing. Do you know what I did wrong?
Posted: Sat Mar 17, 2018 11:58 am
by JohnDeere630
Pin 2 is a PWM pin on the chip. If your 2-pin fan connectors are connected to VCC and GND, they will be on when the motherboard is powered on, irrespective of the firmware settings. A fan draws too much to be powered by an I/O pin from the microprocessor, which tops out at 40 milliamps. It seems that a 3-wire fan may solve your issue.
Posted: Sun Mar 18, 2018 12:12 am
by JustinSB
Ah, sorry, I just found
https://www.geeetech.com/forum/viewtopi ... 821#p82779
and
https://www.geeetech.com/forum/viewtopi ... 38&p=82880
which have all of your notes on this. Thanks.
Posted: Sun Mar 18, 2018 12:35 am
by JustinSB
William,
on the GT2560 Rev A+ board, it has Fan1, Fan2 & Fan3, along with a PWM port that is generally used for a part cooling fan. All of Fan ports have 3 connector pins, although both of the Geeetech fans that are plugged into them only have the two power cables (that's the hotend fan & the circuit board cooling fan). They all have a control pin though.
Do you know what the pin numbers for each fan are so I can use them in Marlin?
Posted: Mon Mar 19, 2018 8:12 pm
JustinSB wrote: Sun Mar 18, 2018 12:35 am William,
The pin number of PWM fan is "7"
Others fan interface are no define
