Can't compile firmware
Posted: Sun May 27, 2018 9:22 pm
I've just fitted the 3dtouch auto levelling sensor and I'm seeking to update the firmware. I've downloaded the indicated file: I3ProW.zip and pulled it into Arduino (v 1.8.5) and tried to build it. Unfortunately, it fails with the errors posted below. Can anyone identify what the problem is?
Thanks.
Tony
Arduino: 1.8.5 (Linux), Board: "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
java.io.IOException: The sketch already contains a file named "Marlin.ino"
at processing.app.Sketch.checkNewFilename(Sketch.java:273)
at processing.app.SketchFile.renameTo(SketchFile.java:179)
at processing.app.SketchController.save(SketchController.java:339)
at processing.app.Editor.handleSave2(Editor.java:2020)
at processing.app.Editor.handleSave(Editor.java:2000)
at processing.app.Editor.handleRun(Editor.java:1718)
at processing.app.Editor.handleRun(Editor.java:1713)
at processing.app.EditorToolbar.mousePressed(EditorToolbar.java:345)
at java.awt.Component.processMouseEvent(Component.java:6536)
at javax.swing.JComponent.processMouseEvent(JComponent.java:3324)
at java.awt.Component.processEvent(Component.java:6304)
at java.awt.Container.processEvent(Container.java:2239)
at java.awt.Component.dispatchEventImpl(Component.java:4889)
at java.awt.Container.dispatchEventImpl(Container.java:2297)
at java.awt.Component.dispatchEvent(Component.java:4711)
at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4904)
at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4532)
at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4476)
at java.awt.Container.dispatchEventImpl(Container.java:2283)
at java.awt.Window.dispatchEventImpl(Window.java:2746)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:760)
at java.awt.EventQueue.access$500(EventQueue.java:97)
at java.awt.EventQueue$3.run(EventQueue.java:709)
at java.awt.EventQueue$3.run(EventQueue.java:703)
at java.security.AccessController.doPrivileged(Native Method)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:74)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:84)
at java.awt.EventQueue$4.run(EventQueue.java:733)
at java.awt.EventQueue$4.run(EventQueue.java:731)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:730)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:205)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:105)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:82)
/usr/share/arduino/arduino-builder -dump-prefs -logger=machine -hardware /usr/share/arduino/hardware -hardware /home/tony/.arduino15/packages -tools /usr/share/arduino/tools-builder -tools /home/tony/.arduino15/packages -libraries /home/tony/code/Arduino/libraries -fqbn=archlinux-arduino:avr
cpu=atmega2560 -ide-version=10805 -build-path /tmp/arduino_build_297291 -warnings=default -build-cache /tmp/arduino_cache_967891 -prefs=build.warn_data_percentage=75 -verbose /tmp/arduino_modified_sketch_428498/Marlin.ino
/usr/share/arduino/arduino-builder -compile -logger=machine -hardware /usr/share/arduino/hardware -hardware /home/tony/.arduino15/packages -tools /usr/share/arduino/tools-builder -tools /home/tony/.arduino15/packages -libraries /home/tony/code/Arduino/libraries -fqbn=archlinux-arduino:avr
Using board 'mega' from platform in folder: /usr/share/arduino/hardware/archlinux-arduino/avr
Using core 'arduino' from platform in folder: /usr/share/arduino/hardware/archlinux-arduino/avr
Build options changed, rebuilding all
Detecting libraries used...
"/usr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -fno-devirtualize -fno-use-cxa-atexit -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-I/usr/share/arduino/hardware/archlinux-arduino/avr/cores/arduino" "-I/usr/share/arduino/hardware/archlinux-arduino/avr/variants/mega" "/tmp/arduino_build_297291/sketch/Marlin.ino.cpp" -o "/dev/null"
"/usr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -fno-devirtualize -fno-use-cxa-atexit -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-I/usr/share/arduino/hardware/archlinux-arduino/avr/cores/arduino" "-I/usr/share/arduino/hardware/archlinux-arduino/avr/variants/mega" "-I/home/tony/code/Arduino/libraries/U8glib/src" "/tmp/arduino_build_297291/sketch/Marlin.ino.cpp" -o "/dev/null"
"/usr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -fno-devirtualize -fno-use-cxa-atexit -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-I/usr/share/arduino/hardware/archlinux-arduino/avr/cores/arduino" "-I/usr/share/arduino/hardware/archlinux-arduino/avr/variants/mega" "-I/home/tony/code/Arduino/libraries/U8glib/src" "/tmp/arduino_build_297291/sketch/Marlin.ino.cpp" -o "/tmp/arduino_build_297291/preproc/ctags_target_for_gcc_minus_e.cpp"
/tmp/arduino_modified_sketch_428498/Marlin.ino:48:14: fatal error: LiquidCrystal.h: No such file or directory
#include <LiquidCrystal.h> // library for character LCD
compilation terminated.
Using library U8glib at version 1.19.1 in folder: /home/tony/code/Arduino/libraries/U8glib
exit status 1
Error compiling for board Arduino/Genuino Mega or Mega 2560.
Thanks.
Tony
exit status 1
