Message d'erreur.
Posted: Wed Jul 18, 2018 5:43 am
by greenskintiger
Bonjour , mon imprimante D200 a subit un choc et depuis lors j'ai un message d'erreur qui apparait :" Error: BED-TEMP the heating element is out of order" et plus moyen d'imprimer.
Lorsque je vais dans le dossier filament , j'ai l'extrudeur barré en rouge avec une température de load à -17°C d'unload à 1°c.
Quand j'ouvre EasyPrint 3D version 1.2.0. le bed monte en température avec une ligne grisée et impossible de faire monter la température de l'extrudeur.Que dois je vérifier ? Merci
- 20180717_113429.jpg (69.9 KiB) Viewed 39359 times
- 20180717_233902.jpg (129.37 KiB) Viewed 39359 times
- 20180717_181407.jpg (300.95 KiB) Viewed 39359 times
Re: Message d'erreur.
Posted: Wed Jul 18, 2018 6:09 pm
by Gingko
You can check the wirings of hotbed and hotend first to see if they are loose.
For the Easyprint, try to change the temperature with the button on the right.
- 2.jpg (214.87 KiB) Viewed 39347 times
Posted: Thu Jul 19, 2018 4:16 am
by greenskintiger
Posted: Thu Jul 19, 2018 10:26 am
by Gingko
You can directly contact the sales, they will help you out.
- 1.jpg (38.3 KiB) Viewed 39325 times
Posted: Sun Nov 03, 2019 7:18 pm
by alan.guerzoni
my name is Alan, from Italy.
I bought a new d200 in 2019, january. it printed perfectly until 2 days ago.
Same error of this topic: "bed-temp". Previsously I had a similar problem, that I solved replacing the nozzle. In this case changing 2 nozzles (1 brand new), the error remains.
Wire from the printer to the head and connectors seems perfect.
Please help me! I'm totally unable of printing!
Regards
Alan
Posted: Mon Nov 04, 2019 9:35 am
Hi, You can try to reconnect the hot bed cable.
If fully accessible, try measuring the thermistor of the hot bed.
Posted: Sat Nov 09, 2019 4:18 pm
by alan.guerzoni
William wrote: Mon Nov 04, 2019 9:35 am
Hi William, thanks.
Apparentlì I solved the problem connecting in a better way the head cable... don't know why but it functionned, at least with only 1/3 nozzles...
Now there is another problem. Printer was printing correctly first 3/4 layers, then stopped every time with every stl. I unmounted the cover of the head and noticed the spring blocking the gear which pull the filament really "soft". Maibe the spring whould be replaced. maybe Someone had the same problem?
Posted: Sat Nov 09, 2019 4:41 pm
Hi,are you referring to the degree of spring tension on the feeder?
If the spring is too loose, there may not be enough force to push the consumables.
If the spring is too tight, biting may occur.
If it is too loose, you can add a cardboard at the lower end of the spring to tighten it.
If it is too tight, it may need to be replaced.
