Repetier-Host not connecting
gamura
Post by gamura »
Hi!
This is not an issue, just something I found out yesterday when I tried to connect my A30 with Repetier-Host, as Ive done with my other 3D-Printers before. First you have to find out what COM port your printer is connected to and setup your printer as usual within Repetier-Host. But you have to set the Baud rate to 115200. My Mecreator uses 250000 Baud as default but when I tried using the same Baud rate for the A30, the printer just restarts and Repetier-Hosts closes the connection when I try to connect. As mentioned, setting the Baud rate to 115200 fixed this issue and now I can print stuff. Perhaps it is just me or my computer but maybe someone faces the same issue. Currently the MeCreator2 and A30 are connected at the same time.
Hope this helps,
Gamura
PS:
I still get some errors like "erro2" from the printer, but I think Repetier-Host just resends the corresponding command again. My prints look good so far.
Re: Repetier-Host not connecting
vuanm
Post by vuanm »
ciao io mi collego con Repetier-Host 2.1.3 ma anche se imposto tutto correttamente inviando la stampa inizia a stampare su un angolo e no al centro anche se io ho posizionato il pezzo al centro sul pc come mai?
Alex-w
Post by Alex-w »
FAQ:viewtopic.php?f=96&t=61534
Mecreator2(GT2560)--Baudrate 250000
A30(GTM32)--Baudrate 115200
Another source: https://github.com/Geeetech3D/Knowledge
