print quality
Posted: Mon Aug 13, 2018 6:34 pm
by frog0
hi i have a problem with the print quality. does anyone know what i could do to resolve it.
Re: print quality
Posted: Tue Aug 14, 2018 4:58 pm
by _kaktus_
I suggest you read this first:
https://www.geeetech.com/forum/viewtopi ... 275#p85275
Applies to a different printer model but the problem is similar.
If in doubt, ask further.
:D
Re: print quality
Posted: Tue Aug 14, 2018 6:20 pm
by Gingko
How much did you set the nozzle diameter and layer height?
Did you calibrate the E step?
Re: print quality
Posted: Sun Aug 19, 2018 12:59 am
by frog0
thanks for replying. i set the nozzle diameter at 0.3 mm and the layer height at 0.35 for the first layer then 0.3 for the rest. i haven't collaborated the esteps and i don't know how to.
Re: print quality
Posted: Tue Aug 28, 2018 4:49 pm
by Gingko
frog0 wrote: Sun Aug 19, 2018 12:59 am thanks for replying. i set the nozzle diameter at 0.3 mm and the layer height at 0.35 for the first layer then 0.3 for the rest. i haven't collaborated the esteps and i don't know how to.
You can try layer height with 0.15-0.2mm for other layers, 0.2-0.3mm for the first layer.
How to calibrate the Estep?
https://www.youtube.com/watch?v=LzZZaGmeX8w
How to change the Estep value?
Use Gcode M92, try to search more information about step/mm change in the forum or Google. :)
