Hot end thermistor.
Posted: Sat Aug 18, 2018 11:31 pm
Hi all.
I am having some trouble with my new i3 Pro W printer. It seems there is a bad connection with the hot end thermistor and keeps giving me MINTEMP errors.
I can start up the printer, raise the bed temp and hot end temp just fine but as soon as the extruder is moved the hot end temp jumps to 0 and gives me a MINTEMP error and cancels the print.
I can move the wires slightly at the hot end and watch the temp readings go from 0 to reading fine.
I have taken the hot end off and tried to get the thermistor out to repair it but it seems to be glued in there pretty tight. Is there anyway to repair this or replace it.
Thank you. IG.
Thank you. IG.
