BL Touch holder / mount for the A10
Do you know if such thing exist? Can anyone make a 3d model ? Geeetech maybe?
The one from Ender 3 is the closest one but it will not fit as the A10 has an extra fan on the left hand side.
Please advise / help ?
Re: BL Touch holder / mount for the A10
You could develop your own holder with: https://www.tinkercad.com/
And print them.
To use autolevel with the A10 you need to change and reconfigure the firmware. The A10 came without any autolevel functions....
And print them.
make your own world - with 3D printing -
My projects on Thingiverse
my own Geeetech A10 firmware
Geeetech A10 LIVE (not always online)
If I knew how to design one I would ask here...
Hi.
Do you want to be a fish or a shark
You haven't even seen this program
To encourage you, I will tell you that my younger son is using it.
It can be pleasant and easy.
Just try it out.
Otherwise, I don't understand why you bought a printer.
Just try it out.
if the development of a holder is the problem, then how do you want to reprogram the system you need to use the holder with a bltouch?
I've already used the autolevel with an proximity sensor and I'm not happy with everyone of them.
Autolevel isn't good to use. Manual leveling over 9 Points and automatic z control at printing are still better then all autolevel versions....
I don't believe that I need to justify myself in front of you or anybody else. If you cannot help (or don't want to) just say it, keep the "moral teachings" for yourself... Otherwise any real help is appreciated.MichaelK wrote: Fri Aug 24, 2018 3:15 amif the development of a holder is the problem, then how do you want to reprogram the system you need to use the holder with a bltouch?
You are so judgemental..._kaktus_ wrote: Fri Aug 24, 2018 2:54 am Hi.
Do you want to be a fish or a shark![]()
You haven't even seen this program![]()
To encourage you, I will tell you that my younger son is using it.![]()
Just try it out.
Otherwise, I don't understand why you bought a printer.![]()
I'm pretty please to drive a car without knowing how to build it or fix it (or program it, with the modern cars).
In the same manner I believe there are thousands of people who want to print (quality prints) without knowing how to design them.
i'am using bltouch and a proximity sensor with the A10. I'am not interesting to help you...
watch my attachment....
good luck to find someone who works for you for free.
- IMG_1132.jpg (621.89 KiB) Viewed 27369 times
