Replacing the glass on the heated be of A10
Posted: Fri Aug 24, 2018 2:36 am
by Hbar
The glass on the heat bed of my Geeetech A10 needs to be replaced. Is there any information on how to replace the glass? It looks like it's glued to the metal bed
Re: Replacing the glass on the heated be of A10
Posted: Fri Aug 24, 2018 3:19 am
by MichaelK
yes, all glasses are glued onto the heatbed.
i'ved never heard that everyone could change the glass only. i'am thinking it's better to replace the heatbed completely....
Posted: Fri Aug 24, 2018 4:37 am
by Hbar
This is an interesting situation, Geeetech support is going to send me a replacement glass for the heat bed but NOT the heatbed saying it is not damage, when I questioned about how to replace the glass on the heat bed they responded to come here to this forum to find the answer.
Posted: Fri Aug 24, 2018 12:38 pm
by MichaelK
Sounds interesting and they make it easy to say: look into the forum......
You could heat up a corner from the bed with a external fan heater and carefully try to tell the corner with a spatula.
Thats all i can think of.
And do it carefully! Use safety goggles!!!
Posted: Sat Aug 25, 2018 3:36 am
by Hbar
It can work easily or it can also damage the heat bed permanently. I'll see when the glass arrives, maybe it comes with instructions
Posted: Sat Aug 25, 2018 1:42 pm
by _kaktus_
Instead of using a spatula, you can try using a very thin steel wire to cut through the adhesive.
The ease with which this operation can be carried out will depend on the type of glue used.
Some glue, at elevated temperatures, begin to lose its adhesive properties.
Posted: Sat Aug 25, 2018 3:42 pm
by Gingko
Posted: Sun Oct 07, 2018 5:27 am
by Kirelam
What good reason would there be to replace the glass plate, except of it being broken?
Regards,
Kirelam
